mikgle
- Jul 31, 2024
- Age
- 71
- mid devon
- MG4 (2022-2025)
Speaking from experience from several years as a sparky, if using a 13A domestic 3 pin socket or the so called EV rated 3 pin socket i would inspect the socket about once a year. Isolate the power and remove the socket fascia. Check carefully for any signs of cracking, burning, charring or discolouring. Give it a sniff test. If in any doubt, replace the socket, they're only a few quid, whilst you've got it open. Make sure you terminate the wires back correctly with a double bend on the copper wire if its solid strand and tight terminations. Test it with a socket tester once live, about £15 . Test the RCD/ RCBO trip for the circuit its on via the test button, or ask a sparky to check out the circuit if it hasn't been done for say 5 years. You're saving several hundred £ by not paying for a full chargepoint, at least spend a bit on maintenance for safety sake! If you don't feel competent, get s sparky to do the checks, they know what to look for, it shouldn't cost much. I would charge about £40 max.on the handover video from the MG website they call it the 'occasional use charger'
